1993 OMC Cobra 5.0 - Which water fuel separator?
Lou C
I think the top one is a finer 10 micron filter, the bottom one probably 20 micron, which is fine for carburated applications, for an EFI engine you'd want the 10. So if you have a carb engine you can use either. I have used these for years and only had a problem once when the threads were not cut right. Tip: make sure it threads on BEFORE filling it with gas!
