1993 mariner 150 disabling oil injection
jimcavy
well i finally made up my mind, i am going to disable the oil injection system and mix the fuel my self. i want to use the boat instead of fixing the motor all the time. what do i need to do to disable the system. is there a way to fack out the sensor on the oil pump so i can keep the warning buzzer for the over heat.
i have all ready made a cover plate out of 1/8 inch thick aluminum with a cork gasket.
what else do i need to do?
thanks for all the great help!!!!!!!
Chris1956
Honorary Supreme Mariner
Re: 1993 mariner 150 disabling oil injection
You can use the pump to cover the hole. Remove the pump, remove the drive shaft and reinstall the pump. Remove the oil lines and conect the oil line to both pump nipples.
