Hello guys, I'm new here and could use some help. I am attempting my 1st rebuild on a 93 Johnson 90hp V4. I have torn maybe 15 apart but never put one back togather yet. I feel confident I can do it. Anyway here is my issue. I have a block that needs to be bored out and I have 4 good .030 pistons to use so I plan on having the block bored .030 over. Well I know 2 of the pistons are Sierrra pistons and not sure of the other 2 but they are stamped 030 on top. When I mic them up the sierra pistons are about 3.519 and .006 smaller OD than the other pair at 3.525? Does anyone know the reason for this and will they work with a standard .030 over bore? Also can I use a standard ring set?
I guess the next question is, if I can use them, would you recomend them to go on the top or bottom cylinders?
Thanks
Thanks
