mattsmall1972
Thread starter- Joined
- May 14, 2006
- 238
Hi - I recently repowered to the 1993 Johnson Oceanrunner 175 and want to understand the VRO hookup before I try it out. Before I ask any questions, I'll say that I really don't want to disconnect it.
1) There are two wires coming out of the pump area where the oil line goes into the tank. I *think* these are a low oil alarm. Am I right, and if so, how do you wire it up?
2) It appears the oil line from the tank takes a bulb pump. Is that all that is needed to prime the oil for startup?
3) Will standard gas line work for this, or is there some kind of other special line that is required for an oil tank? I just want to be cautious here.
Thank you,
Matt
Thank you,
Matt
