1993 johnson 8hp bogging at wot
jworsham06
i have a 1993 Johnson 8hp J8RETB it was in hurricane Katrina and was picked up at auction after being under water for who knows how long I got it unlocked and running took the carb apart and new carb kit in and adjusted so now it runs great at idle but when I put it in the water and give it full throttle it fells like its bogging and wont get the 8ft boat on plane or even close I got good compression and new spark plugs both firing please help with any ideas of what my problem is thanks in advance.
boobie
You could still have some probs in the carb from being under water.
jworsham06
I have soaked it in the carb cleaner, blown out and ran multiple times with the float out the gas will just pour in fine I don't think the carb has any junk in it
nwcove
did you clean out all the passages with a fine strand of wire? just because gas is getting into the carb bowl ok, does not mean its getting to the engine in the right proportions. and do a proper open air spark test at 7/16 gap. it could be running on one cyl
Honorary Supreme Mariner
Bogging is usually fuel related.----Have you pulled the fuel pump apart for inspection ?-----If you are running with a cheap plastic tank you might want to inspect pick-up tube in the tank.
