johnsland8
Thread starter- Joined
- Jul 12, 2008
- 56
I just purchased a boat with a 1993 2-cyl Johnson 50 HP motor. Model VJ50TLETB. PO diclosed that the motor was bad. Looks like it has one bad cylinder, Cyl 1 tested at 155 psi, Cyl 2 tested at 120 psi. I guess the motor will start and run OK initially, then bogs down as it gets warm, makes sense I guess. Anyway, a rebuild seems expensive with machining, etc. so I was looking into just replacing the powerhead with a used or reconditioned one.
My question is, where can I find information that shows me what options I have. I'm not married to 50 HP. Are there other HP and Year options that would work? Can I also use Evinrude from the same years? Where can I find this info? I have done some searching but could not find an easy way to determine this...
Thank you very much for any help you can provide...
