1993 Johnson 4hp deluxe
JMC25
Hello, I am new to fixing outboard motors. I was given a 1993 Johnson 4hp deluxe (model number J4RDHETB) that is in really good shape. It has good compression and spark, so I went ahead and replaced the plugs to try to run it. After a couple pulls, it started right up. I did notice a few problems, one it needs a new impeller because it wasn’t pumping water, and two it needs a new kill switch (got spark because I had to unplug the harness). I was wondering what the part number is for the impeller. I am finding a lot of stuff for 1986-1992 deluxes, would that work or is it a different part? Finally, how would yall recommend getting parts ,trying to find a dealer or website (and which website)? Thank y’all!
Crosbyman
you should have no problems finding
0767407 - Impeller Assembly​
parts look-up shows a small 3 blade impeller starting with the 1993 models
lots of utubes on changing impellers
film495
that motor is lucky, for someone new at fixing outboards you sound like you went over it and checked it out really nicely.
