I have 93 johnson 40hp that runs just fine. After my last outing the throttle control started to get stuck in neutral (i.e. not dis-engage from the neutral position). When I pull the trigger on the control it will not shift into forward or reverse.
After taking things apart, I found a circular shape disk with "u" cut outs that seem to be limits for the throttle position (forward, neutral and reverse). I found that when in neutral the ball seems to come out a bit further and therefore does not allow shifting. I found that I can release it by pressing on the ball bearing and then squeezing/pulling the trigger it will shift, but as soon as you move it back to neutral it will lock up again.
What is the purpose of this ball? I was able to take it out and it seems that the trigger will still only work if squeezed. Is this ball a second level of safety?
Anyways, with the ball removed it seems to work fine, need to take out on the water to test. I would however like for it to be "factory" so if anyone has seen this problem before or know of any fixes or know where i can get diagram, schematic?
Please see pictures in Craigs thread; i have the exact same thing.
http://forums.iboats.com/forum/engi...johnson-60hp-throttle-control-lock-in-neutral
