1993 Johnson 200 venom help!!
Mdayton
I've got a vj200sletc that has progressively gotten worse over the past 4 outings. It started out as when I would start it in the mornings it would be harder to start than normal but when I got her running she would idle good but as soon as I floored it it'd bog and take twice as long to get on a plane and when at wot it'd run 10 mph slower than normal. Well if you stopped and fished for a little while and crunk her up she'd act normal and scream and fly. It's gotten worse every time out since. Now when I floor it it'll start to take off like normal then it'll surge like its starving for fuel or something. Pick up rpms then drop them and pick up again all randomly with no pattern. I'm almost positive it's not mechanical. I've rebuilt the carbs, changed plugs, cleaned recirculation hoses, I'm getting spark to all cylinders, compression is good on all 6. My tach stopped working 2 months ago and I'm pretty sure it's not charging so I know I need a Rectifier but could the rectifier cause these other problems or is it something different? Also with it on the muffs in the yard I pulled plug wires one at a time to make sure they're hitting and the number 4 cylinder seems to not be hitting. Can pull the number 4 wire off and idle not change much if at all. Any info or input would be greatly appreciated. Thanks in advance!!!!
Bosunsmate
Hows plug four acting on spark tester? Jumping a 7/16 gap?
Hows the plug look?
Ground the ht wire and run the engine for twenty seconds, is it getting wet with fuel (ps dont use choke at all during this time)
Honorary Supreme Mariner
Crankcase compression or crankshaft seal ring been checked for # 4 cylinder ?
Mdayton
I have ran if at night and that's all good. And racerone how do you check that? Could that be bad even while it has good compression in that cylinder?
Most folks are confused by this concept of crankcase compression---On your motor there are 6 seperate crankcases and each is seperated from the others by rings on the crankshaft..-----Your cylinder compression is totally seperate from crankcase compression.---You could have zero crankcase compression and excellent compression in the cylinder !!!!
Mdayton
How do you check crankcase compression? And I don't have a spark tester but it jumps a good gap from the plug to the block when I had the plug removed.
Bosunsmate
I'm not sure what the ht wire is?
Thats the high tension lead that goes from the coil to the sparkplug, ground that to a bolt or something ground on the engine as if you run the engine with it just hanging off all that voltage builds up and it can damage electrical components quick.
What you a doing is removing the plug and looking at its colour, noting that down and then cleaning it and sticking it back in without the HT wire attached. Then you run the engine for twenty secs without using the choke, you then take the plug out and check that it is covered in fuel. If it is not it indicates that something is wrong in terms of getting fuel to that cylinder which can be crankcase compression:cold:
daselbee
Kinda waiting for the answer.....how do you check crankcase compression, and to take it a step further, what is the proper spec?
you opened the door.....
