1993 Johnson 140, No ignition
steve.carter
I have a twin motor set up on my boat (2x Johnson 140HP) one of which, all of a sudden lost all ignition. When cranking over there is no spark at the plugs. I have metered the voltages from the ignition switch through to the rectifier and all appears normal. I swapped both the power pack and rectifier between motors - no change in results. <br />In the process I cleaned up & tightened the connectors and earth straps. Suggestions on what to check next would be appreciated........Steve
seahorse5
Re: 1993 Johnson 140, No ignition
Lift up the powerpack and disconnect the black/yellow "kill" wire connection. Make sure the pack ground wire is securely fastened. Then check for spark again. If if it is ok then, you have wiring problems in the motor harness or in the boat. IF no spark still, then you may have a stator or a timer base that is inoperative (or bad connections or wiring), since you are checking with a known good powerpack. Let us know what you find out.<br /><br />this website might help a bit. http://outboardparts.com/troubleshooting/troubleshooting3.htm
D
DJ
Guest
Steve_NZ,<br /><br />Don't forget the simple stuff.<br /><br />1. Is the kill switch lanyard hooked up?<br /><br />2. There is ususally a fuse in a barrel container, near the starter. If it's blown, no spark.
steve.carter
Thanks seahorse & djohns19, I will give those a go today and let you know how it all goes.........Steve
seahorse5
The fuse does not affect the ignition system, just the electrical (start, primer, etc) system.
steve.carter
Thanks seahorse & djohns19, I metered out the kill switch circuits and found no problems there.<br /><br />Yesterday I bought myself a Seloc outboard repair manual #1310.<br />After following the manual's troubleshooter guide,<br />I metered the charge coil and found it to be open circuit - looks like I need to replace the stator/charge assembly.<br /><br />Once again, thanks for your assistance.
