1993 Johnson 120HP
Brayan
Hello I’ve got a 1993 Johnson 120 hp engine # VJ120TXEND.
It starts and it runs but after cruising for about 2-3 miles it dies and it does not want to power back on.
Does anyone have any suggestions on why it does that?
fireman57
Is your tank vent open? Does the primer bulb go flat? Loosen your gas cap and see what happens.
Brayan
Flue cap is fine and also primer bulb stays pumped up. I do have lower pressure reading in one of the cylinders. Any ideas?
Post some compression numbers !-----A " lower pressure reading " means nothing to me.
Either a blown head gasket or very expensive to fix / replace a bad piston.
Brayan
Thanks guys, I guess it’s just time to look for a new one. I appreciate your help.
