REDROCCO16V
- Sep 25, 2013
- 19
Hi, thanks for any advise in advance.
I have recently picked up a 19 ft skiff with a 1991-95 era Force 70hp (I have not ran serial# to confirm exact year) This boat has not been ran/seen water for about 5years/stored in a barn. The previous owner passed away and I don't have any prior info.
My current plan is new water pump, plugs, lower unit service/fluid change and inspection and check compression. Plugs have been pulled and I seafoamed pistons/cyl.
I want to confirm that oil/fuel ratio is 50:1 and is a premix (cannot find any oil injection parts). I plan on seeing if it will run/how well without taking apart the carb at this time (i know not best decision). I am also wanting thoughts on fuel pump, all of my outboards to date are old OMC pressure tank motors. I know engine won't run with out fuel pump but are there any possibilities of hurting engine if old pump fails??
Any other thoughts or suggestions??? I don't want to spend allot on engine till I confirm it is good/stored correctly.
Feels weird to own an outboard newer than 1963.
Thanks Charlie.
Thanks Charlie.
