1993 Force 70hp tach & unknown wires
neverdone
Just picked up old pontoon boat, with 70 hp Force. Hasn't been used for several years. Tach appears hooked up, but won't work....thanks to forum, gonna check for corroded connections.
What are these two wires for, at the engine? they're not the trim.
What would these two wires have been connected to? Coming off the main wiring loom from motor?
Here's the back of the tach with wires hooked up.
Thanks,
jerryjerry05
The1 wire is for the trim sender.
I think the other is for an oil system you don't have.
Mercury used a harness from their motors and it included wires for things Force doesn't have.
The tach is wired right.
Might not be any good.
neverdone
AAAAhhhhh! Good to know about the wire loom just being extra!
thanks so much.
