1993 Force 70 won't start
jybo
I have a 93 force 70 that won't start. I took out the plugs and the top cylinder is not firing. I swapped plug wires and the problem followed (ruling out the plugs which are new by the way). I then swapped the green with the green/white on the back of the coils, and the problem stayed with the green wire moving to the second coil. I then swapped the green and green/white on the switch box (mercury model# 332-7778A10) and the problem followed eliminating the wires. I need to know the wire colors for the inputs to the switch box that I can check to eliminate the box as the problem, or a way of checking this box. I understand these engines like to eat stators and I don't want to buy more non-returnable parts than necessary.<br /><br />Thanks, <br />Paul
