Stoughty Rods
Thread starter- Joined
- Aug 4, 2005
- 17
Hey guys, am I glad I was told about this site. I've been reading a lot of these threads in hopes of finding some answers to my problem. I was hoping I wouldn't have to start a new thread, but looks like I have to. <br /><br />The problem is, it won't idle for very long before it ends up stalling. I talked to a local boat shop and they asked if it ran fine other than in idle. I told them yes and they said turn up the idle. I tried that with no luck. I have it set to 750 RPM's while in gear (like the manual says). <br /><br />I called them back and they said it's got to be timing with the carbs. I got the book out and read on how to sync the carbs. I thought this would be the problem forsure because it had a side not that said <br /><br />Note: Throttle cam adjustment is essential to running at low speeds. If timing is off (either too early or too late) the engine will not perform properly at low speeds.<br /><br />So I make the adjustments and I dropped it into the lake last night. Right off the bat it is doing 10x's better. It's idleing fine and went into gear a couple times without stalling. Then it started to act up....AGAIN! Same symptoms, but it doesn't die out as easly. <br /><br /> - Could this be water in the fuel? I live in S. California (and it has been warm lately) and I'm thinking that when I don't fill the gas tank back up after a trip it may be sweating causing water to mix into the fuel.<br /><br /> - Should I put on a water/fuel seperator in the fuel line?<br /><br /> - I also bought 2 carb re-build kits that I plan on putting on real soon. <br /><br />By me doing the things above, do you think this will get rid of my problem? If you guys can give me any suggestions on what to look for or what to do, I would really appreciate it! - Mike
