1993 excel 18 with 230 volvo penta motor
Status
Not open for further replies.
jphillips78
Just bought this boat and am trying to run it before I put it in the water got my ear muffs on and am running water into the ports behind the prop but it starts to smoke and get hot at the exhaust boot any ideas would help am I doing something wrong ? Help me please I am in Portland and my summers are limited.
Don S
Re: 1993 excel 18 with 3.0 volvo penta motor
Do you have the full model number or serial number for your engine and drive? The 3.0L GM engine wasn't used until 94.
jphillips78
No It's a Volvo 230 a so 4cyl the drive is so cd trim?
jphillips78
Maybe the impeller?
Don S
The impeller is the first thing to check. I am also going to change your title to reflect the engine type.
jphillips78
Thanks do you know where the impeller might be located I probably sound stupid It's my first boat
captmello
the raw water pump, containing the inpeller is #2 in this link. Is located on the right side of the motor on the front with two tubes going into it.
http://www.volvopentastore.com/Cooling-System-Induction-And-Exhaust-Manifold-230a-Sp-A/dm/*******.091755506--**********.953318419--store_id.366--view_id.776923
Here is the pump itself, #5 is the impeller.
http://www.volvopentastore.com/Sea-Water-Pump-855578/dm/*******.091755506--**********.953318419--store_id.366--view_id.776936
You simply remove the cover, pry the impeller out carefully, and replace it with a new one.
jphillips78
Ok I'll try that thanks also can this system become air locked and not pump and the boat is on a hill with the bow facing down could that also cause a problem.
jphillips78
Re: 1993 excel 18 with 230 volvo penta motor
Ok so its not so much that its over heating its that I'm not getting any water out or the exhaust
Don S
Where is the water coming out at?
jphillips78
Ok I figured it out so simple the pump was air locked I had to fill the resiviour while it was running to get the air out now it works just fine
jphillips78
Going to take her out today see how she does wish us luck
Status
