1993 Evinrude Spark Plug Gap
dnyelator
The online charts say to gap at 0.03 for my 120 HP, V4. Is that right? If I'm reading correctly that is 0.75mm, which is very tight. The plugs I pulled out were at 0.4 or 0.5. Please help!
​Thanks
Vic.S
​Thanks
Generally the recommended plug gps for most (all??) of the 2 strokes were revised from 0.040" to 0.030" in the late 1980s (??)
I would have thought that your 1913 owners manual would have said .030"..Does it not ?
My 1984 owners manual says 0.040" but the latest recommendation is 0.030"
dnyelator
​Thanks Vic, I admit I didn't look in the manual, looked it up online, its just that the existing plugs that came out of it are gapped way larger, like I said 0.50, the plugs I bought are also gapped at like 0.40 and 0.50 vs. 0.03. My feeler gauge is in mm, when I crossed 0.03 to mm, I came up with 0.75mm, which is very small. When I bent the prong it just looked so tight I was really surprised, but I'll go with that and swap them out and see how she runs. Thanks for the reply.
interalian
Gaps wear open pretty fast on these motors. I set mine new to 30 thou and they were worn to 40 by the end of season.
dnyelator
​You say 30, but don't you really mean .030? That's where I was getting confused. My round feeler gauge only goes down to 30, but that is a lot more than .030. I gapped them at 0.75mm and put them in and it seems be running OK. It's never ran great, but it runs, so I guess that's where they need to be. Thanks for the assistance folks!
interalian
30 thou is mechanic's, engineer's and draftsman's shorthand for thirty one-thousandths of an inch. It equals 0.762mm.
dnyelator
Thank you sir. Now I know. I misunderstood your "thou" to be "though" vs. "thousands". Should have known. My bad. So I set them to 0.75mm...thanks!
interalian
Sometimes I need to remember my jargon may not match everybody's interpretation. A good reminder for me to be more precise. Another example would be 'mil' which old timers use in place of 'thou' as well - that one mixes up people with a passing familliarity with the Metric system.
