Maddmunkey
Thread starter- Joined
- Jan 2, 2017
- 3
Hello everyone, I have been a lurker on these forums for a while and got some great info. I'm having an issue with the correct propping on the boat and motor combo I'm running. First off the boat is an early 90's tidecraft 1300 series 15ft with a shallow v hull. The boat weighs in dry at 700lbs + 550lbs of people and gear. The motor is a 1993 evinrude 40hp 2cly 2stroke with a 13x11 prop that was originally on it.
The motor had issues with the timing advance and was fixed along with rebuilt carbs and a new power pack. Motor is synced well and runs apparently good. I have played with pitch, prop height and hydro fin non has made a noticeable difference in speed and performance.
At wot motor runs at 4000rpm moving 16mph with13x11 and my partner has to counter balance front of boat and does not plane.
Switched to 12x15 per forums I've read. Motor runs at 3800 rpm at 16 mph same issues as previously noted.
Switched to a 13x10 motor would cavatate at roughly 5mph
Then over revved till I reduced throttle.
What am I missing? Motor issue still? Motor underpowered for boat? Recommended prop? Any info advice would be greatly appreciated. Feel free to ask for any more info needed. I am determined to figure this thing out. Thanks guys and gals.
