1993 Evinrude 115 HPTilt/Trim not working
rmillik
My 1993 Evinrude 115 w/power tilt/trim will only tilt up. I have to use the manual release to get the motor back down. I'm using the switch on the engine-the one on the control handle appears inoperative. I just picked up this boat so all help is greatly appreciated.
boobie
Swap the tilt/trim relays on the motor and see what happens.
emdsapmgr
You could have a bad trim switch on the control box handle. Check it with a continuity tester.
emdsapmgr
You could have a bad switch on the control box handle. It can be disconnected and tested with a continuity tester.
