1993 evenrude 70 hp compression
adamjenzerr
I was changing my plugs today and noticed a bit of oil on the plugs. I did a compression test and the results are
top cylinder 90
middle is 65
bottom is 90
Advise?
It runs great
flyingscott
that's pretty common for the middle cylinder to be damaged on those. There was a service bulletin for the peehole to be re located to the top of the block to prevent that. Is that Done? try a different gauge, or pull the head off
adamjenzerr
I just moved the pee hole last week which I assume was too late.
What do you mean try a different gauge?
As stated very common for #2 to be KAPUT.----The service bulletin came out in 1994 to move the telltale.-----But these motors are good and rarely need to visit the Evinrude hospital I think.
flyingscott
When the head comes off you can see it. It will be on the piston either a part# and or size. May need to clean the pistons off to see it
