1993 bass tracker tx 17
thefishermann
i have a 1993 bass tracker tx 17 and the fuse panel is corroded i have been to several authorized tracker dealers and no one can seem to help me can anyone help me i am very fustrated
gm280
Tell us what you're needing and see what we can come up with. Post some pictures of your problem with the control panel and we can point you in the right direction to fix it yourself or to someone that can... Corrosion is a reoccurring issue and not a show stopper. So post those pictures for us to see what you see...
Silvertip
Honorary Supreme Mariner
There are an abundance of fuse panels available right here on the iBoats Store. Pull out the old and install the new one. Electrons don't care what the panel looks like so it does not have to be a factory replacement part.
bonz_d
Yes sir indeed. There are a couple different styles you can go with. Like the ones with the circuit breakers or the ones with the old type glass fuses next to each switch. Then there are rocker or toggle switches. They will all work, some are more expensive than others. Just find one that matches the current size panel if you can.
