Recently rebuilt 90HP Johnson that was overheated big time. Wires were melted including both temperature sensors.
Started the boat up ran awesome when it got up to temp about 170 the horn started to sound about every 20 seconds or so.
Looked it up said that meant low oil. Filled the oil before 1[SUP]st[/SUP] try so knew that cant be it. Also running 50 to 1 in the tank for the new pistons.
Stopped to fish after about a 20 minuet ride on the lake. Went to start it back up couldn?t get it to start. Got it back home fired right up.
Went back out the next day running great 5000RPM about 42 MPH still chirping at temp though but its not over heating.
3[SUP]rd[/SUP] time out fired up great ran awesome hit a big wake then lost 2 cylinders. Took off the power pack to inspect the wires checked the plugs switched the around fired back up
Sounded great until I hit 2500RPM then the 2 cylinders cut out again. I tried disconnecting the temp sensors to see if that was putting it into the S.L.O.W. mode.
In the trouble shooting it says to check the diode showed on test it was bad so cut open the harness all I found was a crimp. Looking at the wiring diagram it dose not show a diode.
Can anyone help?
Can anyone help?
