1993 70 nissan light backfire
junior1113
just got this boat. been sitting for years. i got it running good except the light mis in bottom cylinder. seems like a little smoke comes up from main gasket. bottom of lower cowling. havnt done carbs could this be the problem. p.s this is on the hose running
pvanv
Re: 1993 70 nissan light backfire
The smoke could be oil and junk burning off, or you may need a new base gasket -- where the exhaust housing bolts to the powerhead.
Prudent to go through the carbs and check everything over.
junior1113
thanks for your time NS70A2. HAVENT TOUCHED CARBS COULD THIS MAKE THESE SYMTOMS? PULLED NEW PLUGS AND BOTTOM PLUG WAS BLACK JUST FROM 10 MIN IDLE ON HOSE
TOHATSU GURU
Carburetors can't cause a backfire, however they can cause the engine to run rich if they are not set correctly. But, you need to consider something before you go any further with this engine....It's 17 years old, they stopped making parts for it years ago and virtually nothing is available for it anymore. Be very careful with the money you spend on it as whatever you fix today will not count when something else breaks tomorrow.
junior1113
really, just want to know what could cause this coughing (backfire).?
TOHATSU GURU
If you have a true backfire: Broken flywheel key, bad trigger coil, bad CD module or a twisted crank....The crank and trigger coil are no longer available.
junior1113
ok, adjusted carbs and runs perfect. lower carb low speed jet clogged. carb can make engine light backfire.
TOHATSU GURU
Actually, a carburetor cannot cause a backfire. I think you are confusing a miss/pop with a backfire.
junior1113
hey it was a miss/ pop sorry i worded it wrong thanks for your time though.
TOHATSU GURU
Not a problem at all. The only reason I try to make things like that clear is because the terminology makes a difference when you try to diagnose something without being there:)
