Re: 1993 6 hp backfiring and wont rev up
Well, that pretty much exhausts my ideas since I am not personally familiar with your particular motor. Perhaps others with more experience can help out.
An external spark test is where you use a gap spark tester, set at a particular gap. In this case 3/8". Remove the spark plugs and connect one end of the tester to a spark plug boot and the other to a suitable ground and pull the starter rope. If you see a spark jump that gap, your ignition is very strong. If you don't it isn't.
It could be the coil since they can show intermittent failures when they heat up. It could also be the powerpack. My motors are too old for powerpacks so again, someone else will have to advise on that. The other thing to look at is the link and sync. This is where the spark's timing advance gets synchronized with your carburetor. It ensures that the spark is firing at the right time throughout all the RPM ranges. Perhaps it is set too far past TDC and it's delayed firing is allowing fuel to escape out the exhaust and backfiring and bogging down from lack of power. Just throwing out ideas. Again, since I am not familiar with your motor I cannot give advice on how to ensure this is set right. Wish I could add more advice.
