All, I am having an issue with the Mercruiser 5.7 in my 1993 Regal 233 with the alpha 1 gen 2 sterndrive. I picked up the boat end of last season and didn't get much run time on it, but I had some issues with hard starts, low power, stumbling, and stalling. I checked the timing (8deg BTDC), cylinder compression, changed the plugs, and checked the distributor. The timing was good and the cylinder compression was good. The distributor had a small amount of oil sitting in the bottom of it and the rotor/cap contacts were a little dirty. I cleaned this out and hit the rotor and cap contacts with a little sandpaper to clean off. It runs better now, but I am still struggling with lower power and what sounds like a stumble or a miss at WOT. Any thoughts on what to go after? Spark? Fuel? I linked a few videos below.
