1993 5.7 Mercruiser aplha 1 wont start
edrauch
After a weekend of trouble shooting i've come to you for HELP! I have a 1993 5.7 Mercruiser aplha 1 gen II ( thunderbolt IV) that wont start. It ran perfect 4 days ago! It turns over great and the battery is new and fully charged. I have no spark at the coil. I have good fuel at the carb. I have replaced: coil, distributer cap, rotor, sensor, plugs. (plug wires were out of stock) I have the manuals and know i need 12 v at the coil, I have nothing. What should I look at next? Thanks
Scarab95
Re: 1993 5.7 Mercruiser aplha 1 wont start
Have you checked the ECM gizmo on the backside of the distributor?
danond
I believe your coil gets 12v from the post on the starter, or the starter assist solenoid. Maybe try cleaning up all those connections and see if the problem continues.
edrauch
Checked connections and the ingnition EMC on the back of the distrubutor. Nothing. Next?
Bt Doctur
Safety lanyard switch
bad /shorted tach
edrauch
Thanks for your help, I disconected the tach from the coil today.... nothing. I jumped the kill switch....nothing. I pulled it to the shop and dropped it off. Thanks. E
