My Johnson motor was running perfect then the next day when I started it I noticed the motor wouldn't idle down, and would only run on half or more throttle. After some investigating I noticed that only the bottom cylinder was firing. If we run with the top spark plug out there is a mixture of gas and water spitting out the top spark plug hole. So I changed the head gasket and the crank case seal and still have water spitting out the spark plug hole. Is there something else that can be letting water into the cylinder ?
Note: compression test 145 on top cylinder and 160 on bottom.
Both carbs torn down and cleaned
Also tried starting dry so no water in the cylinder but still will not fire
Running out of ideas
Thanks
Thanks
