1993 40 hp evinrude won't start
cecilp
have a 1993 40 hp evinrude that refuses to start. no spark on either cylinder. compression is 130 on each cylinder. trigger, stator replaced 8 months ago by a " parts changer ". motor was running fine one day and the next it started and went to wide open trottle and it has not fired since. coils check 00.1 ohms and 289 ohms respectfully. power pack reads 88.85 ohms at blue wire, and 7.78 ohms at green wire and 0 ohms on white wire. fuel supply is good and primer supplys fuel as design when choked.
Test components under the flywheel.----Charge coil and sensor coil.-----Flywheel does not need to be removed for this test.-----Explain " went to wide open throttle "------Checked flywheel key ?
cecilp
had trottle in neutral position and it got pushed full forward. engine was cut off immediately' got any readings for fly wheel components
