1993 30hp 2 stroke Tohatsu Spec Sheet
gatorsc
Looking into purchasing a 1993 30 hp Tohatsu and wanted to see if anyone knows if there is a spec sheet to see about the motor's weight and whatnot. Any info is appreciated!
pvanv
Re: 1993 30hp 2 stroke Tohatsu Spec Sheet
That info is in the Service Data book. Mine is at the office, and I won't be there until tomorrow. You will need the correct model and serial (not year of manufacture), and you can drop me an email at paul@obersheimersails.com, and I can check it for you.
gatorsc
Thank you sir, if I can get that info I will be in touch
TOHATSU GURU
Base model is 102-104 lbs. Specs can be found in the service manual.
gatorsc
Thanks again, would have checked the manual if one avalible.
TGuy
weights (and whatnot) specs are also in the owner's manual which you can download for free from the tohatsu.com website. All the owner's manuals are listed under the Tech. Info section of their website.
deejaycee_2000
see attached
