fiveonadub
Thread starter- Joined
- Jul 3, 2015
- 14
Hi,
I have scoured the forums for a fix. I do not want to throw parts at it.
I have 90 psi across all 6 cylinders.
Spark jumps 1/2 inch+- gap
bought the boat a month ago, ran great. '85 21' auaquasport? '93 200hp evinrude.
was running great ....Suddenly at WOT it stumbles...I limp to the dock, pull the fuel filter and it had blue rvt in it. I blew it out, it ran for a minute then crapped out.
I am not sure the rvt had anything to do with it.
So took it home, shot carb cleaner all in it and new plugs etc..ran like a champ on muffs. Got it to the dock, got one good hole shot...then couldnt get over 1000 rpms.
Gave up, went home.
When my wife pumped the bulb on way back to dock, the motor started to wind up but quickly died out to 500 rpms and stumbled died. Eventually the only way I could get it to run back to the dock was by choking it.
I have new fuel lines and bulb.
I first suspected the pump. Is there a way to test it?
The oiler gimmick has been removed and the hole that feeds it was not plugged.
what about the solenoid thing with the red lever? could that be my problem?
How can I diagnose this properly?
Can I use a generic fuel pump?
Thank you for your help.
Gave up, went home.
