Re: 1993 150HP Johnson 3Cylinders down.
Any overheat/shutdown, alarm scenerio "history" here? Ijust put my 1990 'x-flow' 150 back together (johnson). there was an overheat involved (no alarm). the port side cyl's scored, starboards ok. I found one water deflector between #1 & #3 deteriorated, split and blocking water flow in that area. your story sounds familliar.Oh yea, I found a broken wire on the alarm switch on the port head. Is that '93 model of yours a looper? I don't know if the set up is much different or not - good luck
