1993 150 Merc carb adjustment
eddy2419
Thank you sir. My son is having an issue and has pretty much no money. I do not know carbs well either.
Chris1956
You really should adjust them on the water, motor warm, fresh fuel and in gear at idle. It takes some patience to get all 6 of them set properly.
That motor will run very well, if the timing and carbs are adjusted well.
