1992 Stratos 201 Pro XL Evenrude 200XP
Hawgmaster
Hi, I have a 1992 Evenrude ve200slens outboard. I've owned the boat for 24 yrs. its been a wonderful boat until now? Lol, I put the boat in the shop, they replaced power pak, cleaned & rebuilt every carburetor, new plugs, installed fuel-water separator. New impeller, I ran the boat, it skips on the hole shot & skips at wot. It runs ok at 4800 rpm's. When I open the throttle wide open it just stalls & never revs over 5,000 rpms. When I back off the throttle to 4700-4800 rpms it runs ok? I pulled the 3 spark plugs on the left side of engine & they look ok? When I pulled the 3 plugs on the right side they were all black & oily? Could it be the the carbs on the right side are just running to rich & need adjusting? I greatly appreciate any help? Thanks
ggodwin
When was it last running good? Why did you put it in the shop? Did this problem occur over night? Over the winter? Just after leaving the shop?
I'd confirm fire getting to right side before I did anything else. I know black carbon plugs can indicate a rich mixture. But, the plugs should look similar. It doesn't make sense that the shop screwed up the carbs just on the right side only.
I'd be incline to think you have an electrical issue just on that right bank. Possibly a kill switch wire that is intermittently have a bad connection. Maybe shift interrupt switch. Regardless, start with a spark test and go from there.
Hawgmaster
Thanks ggodwin, end of last summer I purchased gas that had a lot of water in it? The gas station admitted they had a problem & put in new tanks, lines & pumps. My boat has not run right since? I took my boat to a shop that has been in business for 30 yrs. They also cleaned out the fuel tank & gas lines. I actually picked up my boat & tried to run it & had to take it back to there shop 3 more times because it wouldn't run right?? They finally told me they had done everything they could? They gave me a slight break on my bill and said good luck? I will check spark on the right bank of cylinders. Thanks again for ur help!!
