1992 lowe 2200 deck boat . What's the fuel tank gallons???
richjms
Thanks wont work its 3/4 full .I'm gonna fill it up then unhook my oil injection . Then need to know my total gallons to mix in my oil . Thanks
GA_Boater
Drain and measure. Or throw it your car or truck, then start from scratch for the oil/gas ratio.
BTW - Even if you know the tank size, that won't tell how much is actually in the tank.
richjms
Did t mean it WONT work . There should be info somewhere on the gallons that boat comes with . Like I researched my 92 crestliner . When I removed oil pump . Just thought SOMEONE might have that info . And Ga boater you are wring you can get measurements of tank and determine gallons . But my tank is under floor . Thanks
GA_Boater
I know the tank size, but I don't like to be told I'm wrong. The answer is on the Interweb and didn't take long to find.
Yeah, I'm having a bad day. 27 GALLONS
richjms
Yea your wrong , and I'll tell ya again if you are indeed wrong . Dont care weather you like it or not . Just figured this would be a place to find a answer not to be ridiculed. Wont ask another question on here that's for sure . By the way it's a 27 Gal.
GA_Boater
Too bad you didn't quote my reply. Try it.
And no, I'm not wrong with the answer I gave. You're wrong for thinking you can denigrate people trying to help if you don't like the answer.
I still have a question - How much gas is in the tank? 20 gallons or is it more or less? How will you know? Better over add 2 stroke oil and don't assume it has 20 gallons.
it still make me laugh when people remove perfectly good oiling systems from 2-strokes
