I have a 1992 60hp Johnson that will not turn off with the key. Have not been able to find a loose or broken wire. What else can cause this? We have already changed the switch.
Power pack not grounded. Bad ground wire. Poor installation of switch. Blk/yel wire broken. Just to name a few. Isolate and ohm out blk yel wire from key switch to red plug. There is a red plug diagram you can search for in the sticky up top
I've had two different OMC's that had that same problem. Both were dual pack engines. One pack was a used replacement, the other was a brand new defective factory one. Anyway, neither pack responded to the kill wire. When the key was turned off, one pack would quit, the other kept firing. This was 10 years apart, one a V4, the other a V6. Replaced the one bad pack on each engine and they shut off normally. The new factory pack was warrantied by Bombardier.
