1992 johnson gt200
rb215
Help needed I have a 1992 johnson gt200 on a 20 ft nitro Motor is bogging bad when I try to get on plane hit’s 3000 rpms and set there until I play with trim finally gets on plane but will only turn 5000 rpm on top end.The boat used to have a great hole shot and would run around 70 mph according to past owner witch is a friend so I believe him boat sat for three years before I got it. Ok now for things that have been replaced stator timmer base three coils plugs water pump carbs cleaned vro disconnected running premix 50/1 had compression checked 75 psi on all 6 cylinder Still stalling at full throttle trying to get on plane Have read on about ever boat form there is found about 5 people with same problem but no tells what fixed the problem I hope someone can help with this
Honorary Supreme Mariner
Do a test for spark.-----Sounds like it is running on 5 of the six cylinders.----And perhaps use a strong flashlight to look into the carburetor bores to compare how fuel comes up the main nozzles.
rb215
we did the spark test had three weak coils replaced them checked all coil again spark was 7/16 like manual says
Thanks so much for your reply
Have a shop look into possible issues with crankcase compression.
Your motor has 6 separate crankcases.-------There are sealing rings on the crankshaft.-----There have been issues with these sealing rings.-------Compression would leak from one cylinder to the next resulting in performance issues.-----I can't help you other than suggesting where to look.-----Seems you have looked all over the ignition and carburetors already.----The 75 PSI compression in cylinders would also be a concern to me.----Perhaps pull one cylinder head as a new head gasket is cheap.
