1992 Johnson 9.9 Carburetor Replacements
rothrock
I just picked up a pontoon boat that was fitted with a 1992 Johnson 9.9 (J10RELENA). The boat and motor sat for 7 years. Upon opening the carb, I found that the main high speed nozzle was broken in half. So I have 2 questions. Is this carb repairable? If not, what other year of carbs will work on this motor? I'm having a hard time finding an exact "1992" 9.9 carb.
I wouldn't be against fitting it with a 15hp carb, assuming I can find one.
flyingscott
High speed jet is pretty small hard to believe that one got broke. Do you mean the low speed jet the one that screws in the front of the motor. If it is the low speed jet the top of the carb can be replaced along with the needle valve.
rothrock
Maybe i'm wrong on the name. It's the one that goes through the middle of the carb body and is right on the other side of the butterfly. It goes down into the bowl through the nozzle well.
flyingscott
Put a pic up and a carb from 88-92 interchange as long as they have the plastic top.
rothrock
This isn't my picture, but just to show you what is broke. The part right in the middle of the carb with the slot cut into it.
rothrock
No Title
It looks pretty close.. Attached are the pictures of mine that I took last night. I don't have any pics of the part in question, or of the throat.
flyingscott
The part that's broke can't really be fixed. Maybe someone else here has fixed one before.
raczekp1
hi. can you mesure diameter in restrictor plate? if there is one under the carb
thumbnut
Its the main nozzle feed tube. Take a 500 watt soldering iron and sweat it up..Use a drill bit by hand to clear any excess solder. I'd use lead rather than silver solder. One might be able to use a 35 watt iron, more likely to have one at home..
rothrock
There is no restrictor plate.
Attached are a couple more pictures. Can this part be purchased? Its completely removed from the carb.
thumbnut
Oh...no soldering that...
Somewhere I saw a pack of them on ebay not too long ago..
rothrock
None of them that he has for sale match exactly what mine looks like. I messaged to get the diameter to see if it would fit, I might be able to get it to work.
rothrock
A local boat shop has a 9.9 carb from 1998. Will that work? It looked like the fuel inlet was on the opposite side tho.
They did inform me that my carb is actually a 15hp, not a 9.9.
raczekp1
carbs from motors 9.9/15 made from 1993-2005 have diffeent chocke arm activator, and slow speed needle is at the side of carb instead at front as previus model have
rothrock
I found a couple parts carbs at a different local boat shop and found a pickup that I was able to remove from one of those carbs and put it in mine.
After cleaning everything out and putting it back together, it is working great hooked to the hose. I hope to get it on the water this week to try it out.
