homer-j-simpson137
Thread starter- Joined
- Jul 10, 2014
- 2
I have a 1992 Johnson 48SPL which has dual new batteries with a Blue Seas switch and an ACR. I know this motor has a small charging system on it (I think it's 6 amps), but my problem is that I never see more than 12.5 volts on a digital volt meter and this is running wide open for 20 minutes or so. I have replaced the rectifier as well as the marina replaced the stator last summer. I am an electronic engineer by trade and have this thing wired very nicely, but this low voltage problem is kicking my butt. At one time, shortly after replacing the rectifier last summer, I did see the voltage go up to 13 to 14 and even 15 volts, but this somehow stopped and once again it's back to never getting over 12.5 volts at full throttle. The only thing that hasn't been checked, is the magnets inside the flywheel, but people keep telling me this couldn't be the issue. If anyone could help I would greatly appreciate it. I know this motor my have a small 6 amp charging system, but this doesn't mean it can't do 13, 14 or even 15 volts output.
PS, when running at full throttle, and only reading 12.5 volts max, I have nothing else on (no radio, lights, ect.).
Also note that I took the rectifier off and had it checked by my boat dealer. He said it was OK, so I reinstalled it.
Thanks for any help,
Mike
Mike
