1992 Johnson 30 horse fuel issues???
FLETCHxj
I just bought a 92 johnson. I could not get it to run. The spark is good and the fuel pump seems to be good. While trying to start it if you back the schraeder valve off a little it will run for a few seconds while the fuel is coming out but when closed it will not. I am new to boat motors and probably need to rebuild the carb but thought someone might have a suggestion. Thanks.
boobie
Re: 1992 Johnson 30 horse fuel issues???
How did you check your spark ?? At first guess it sounds like carb repair.
boobie
Did you check the spark with just the plugs or an open air gap spark tester ?? What's the compression on it ??
