1992 Johnson 25 hp, add a pull start?
1956 Richline
I have a 92 Johnson 25 hp electric start outboard and I want to add a pull start to it. There are three mounting bolt holes around the starter fly wheel on the top of the power head. And in the cover is a removable panel about the size and position that a pull start rope could fit if a hole was cut.
So my question is, would it be possible to find a pull starter that I could mount onto this motor and make it a pull start and electric start?
flyingscott
Yes easy to add manual start try to find a used recoil that has the neutral safety cable on it. But usually you need to buy a new hood also.
