If you ain't first you're last
Thread starter- Joined
- Oct 11, 2018
- 13
I recently got a new outboard and went to test it out yesterday starts and ran great ran it for about 20 minutes between all speeds head back to the trailer and the temp alarm went off while idling waiting to load. Today I got the infrared thermometer out hook it up to muffs to temp check the heads to make sure it was actually overheating and it was and fast. Smeed to pee ok.Got up to 200 in just a few seconds shut it off and took the lower off. Checked the impeller and it seemed fine there was some sand that I cleaned out. Took the thermostats out and they looked fine as well. Tested them and the opened at 160ish. Ran the hose down from the head to try and flush anything out and water seemed to travel no problem. Screwed the hose in from the pee hole and flushed down from there. Fyi I had the thermostats out and open and after 30 seconds to a minute water built up to the top of the heads and was flowing inside them fine. Ran the hose up the lower and flushed up. Put everything back together and Still overheating. I'll order new thermostats and impeller tomorrow when the shop opens just to be safe but want to see if I missed anything or if anyone knows any tricks? Thanks for the help guys
