Re: 1992 Force Sitting 7yr
Chances are motor is locked up so your gonig to need to free it up by spinning the Flywheel manually. use a rachet on the flywheel bolt to turn it if you cant get it to spin after it starts spinning spin it a few times, thats a start. it might be really really really tough and your going to go through a few rachets too i had to free up a 87 Merc 200 BlackMax went through 3 craftsman rachets with a 3 foot peice of condo-it on the end before it free'd up, of cource after you get it running id change the lower unit oil and the whole water pump. if you dont get it free'd by a rachet you might have to alternate from bumping the starter to rachet becareful to not overheat the starter once you see smoke stop. let it rest a while before you try to bump it again.
