1992 Force 40hp trim/tilt controls
bh357
What is needed for controls for the trim and tilt unit on this motor? Are there relays/solenoids that are needed? I have the tilt cylander, and will be getting a motor/pump assembly, but I need to know what is necessary for controls. My manual (Force Service) doesn't go into great detail here.<br /><br />Thanks,<br />Brad
roscoe
Re: 1992 Force 40hp trim/tilt controls
Are you getting the factory components that came on that motor?<br />If so, I would go to a Mercury dealer for wiring harness that plugs into the relays. You will need wires to switch at helm.<br /><br />Or got to Mercury Part Express website, type in your serial number, and it will show you the exploded view diagrams of what you need.<br /><br /> http://www.mercurypartsexpress.com/PartsExpress/ProductSelection/ServiceParts/sphome.asp?CID= <br /><br />Good luck with your project.
