1992 force 150
ceagle
The motor is a 1993 150h.p. Force. The motor idles fine, but above 1000 rpm's it shakes really hard and smokes more than normal. It is an inline 5 and acts like it is firing on only a couple cylinders. It does this even in neutral and will cut off if you do not throttle back. It does not seem to be a fuel problem as best as I can tell. Thanks for any suggestions
force01
Re: 1992 force 150
after checking your compression see if you can see any water in the cylinders those motors are prone to blowing exhaust gaskets. good luck, bret<br /><br /> If you need further assistance please email me @ forcepower01@yahoo.com.
