1992 Force 120hp Stator Issues
JKelley80
I have a 1992 Force 120hp that I recently replaced the stator due to a no spark issue. However, after I installed the new stator it started up just 3 times before the new stator blew. Any ideas on what could be causing these stators to blow? I ran all kinds of checks before determining it was the stator when I first found the no spark issue. I'm afraid I might be missing something, as I am a novice with outboard engines.
jerryjerry05
Who'd you buy from?
Most aftermarket are CDI
Contact them and ask there.
They can answer most questions.
​They can short or blow from a bad ground somewhere in the system or a bad connection.
