bishop1976
Thread starter- Joined
- Dec 13, 2007
- 93
I have a 1992 Evinrude 48 SPL. Had it rebuilt in 07 and it has less than two hours on it. I start it up and run it on the muffs every other week to keep it fresh. Recently when I turned on the key the alarm stayed on without starting the motor. I was able to turn the key off and back on a few times to make it go away. Now its constant from the moment the key is turned on to running the motor or not running the motor. I disconnected the temp wire at the motor and still get the alarm. My manual says this is the only sensor my motor has (or the only one it lists under alarms). Any ideas what might cause this?
Additionally I would like to get tilt and trim for this outboard. It currently has a tilt assist cylinder that is about kaput. What should I look for new or used? Part or model numbers?
