Got a bass boat for what I thought was a deal. Can't get the motor to play nicely. It's a 1992 evinrude 40hp 2 stroke (TE40ELENM). Will not start in neutral I have to advance the throttle about half way up. Once started it runs at around 1200 RPM. Advance the throttle and it'll bog down then it starts to jerk like a cylinder is missing. Back the throttle off toward neutral and it just slowly winds down. So I pulled the carbs off tore them down cleaned them (2 hours in a bucket of carb cleaner followed by a trip threw the ultrasonic cleaner then a rinse with carb cleaner and blow down with the air compressor) rebuild kit for the reassemble with no change on engine operation. I have spark on both cylinders, 120 psi on top 115 on bottom. Did the carb sync procedure verfied all lines on the motor. Even tried a different fuel source. Pulled the upper plug out and started in on 1 cylinder ran it stills bogs at higher throttle sputters out at lower same with the procedure repeated on the lower cylinder. New plugs, new plug wires, fuel pump / VRO pump pulled cleaned, new fuel filter, and redid the impeller just for the hell of it. I am truly out of ideas. Nothing has changed how this motor runs which leads me to believe I haven't even touched what's causing the issue. Weak spark? How would I check that (the seloc manual is less than helpful) timing? (18ish at WOT while bogging can't check idle motor won't run that low). Please help as I'm almost out of money to fill this hole in the water with (that I've never had in the water). Thanks.
