1992 evinrude 30 hp broken shiftrod
Powell masonry
Looking for advice on a broken shift rod it snapped where the keeper would be. I also cannot get the lower unit to drop it is stuck at the one stud bolt in the front. I've bent it a little from beating on it. Am I missing any other connections?
kodibass
Master Chief Petty Officer
Shift rod, grind both parts to a point and weld back together with #309 SS rod, Front bolt, drill 2 small holes on three sides 6 holes thru aluminum spray in PB blaster into holes ( use drill bit to allow plastic straw on spray lube to just fit inside holes ) Let soak for a couple days spraying & use a propane torch to put thru heat cool cycles, spay,soak,heat,cool. several times over a couple days. When re-assembling fill small holes with JB Quick weld sand & paint. kodi
Powell masonry
thanks for the In put sounds like a big process. The piece the broke off is only 1/8" looks like. if I buy a new shift rods is it I big deal also? Should I completely trash the stubborn stud bolt and use vice grips on it and order a new one as well? Need to minimize time, spend money and duck hunt asap!
oldboat1
well, IMO need to replace it. Depending on where it's broke, though, might improvise -- maybe a piece of tight fitting fuel hose, clamped at each end of the break. Have to take it slow! Can't change the length of the shift rod, as it would be when regularly connected.
Powell masonry
That's a great idea for a quick fix! The nut on the bottom won't move does that have a keeper as well?
Apply heat to the area round the front stud.--There is a guide tube around that area to align things.---That tube / dowel jams up with corrosion.------Post picture of the broken shift rod too.
Powell masonry
Got the lower unit off finally not much to see except a corroded and broke shift rod where the keeper would be. Kind of stumped on getting that replaced from the midsection any suggestions please
The shift rod is pinned at the top.----Powerhead needs to be removed.
