ijmckenzie
- Apr 29, 2013
- 13
Hey guys,
I've been reading these forums for a while but I can't seem to find any info on my current problem. Really what I need help with is diagnosing what part has gone bad. So here goes...
The problem: I was coming back from fishing the other day at WOT doing about 30 knots. All of a sudden the my rpms and speed dropped by roughly half. (I don't have a tach but speed went to 15 kn).
What I have done so far: I figured I might have a bad power pack so I cranked the boat up in the yard and started pulling the "spark plug connector heads." Sorry guys I actually don't have any formal training in engine repair so honestly I don't really know what to call certain things...So try to bare with me on that. Any way I pulled #1 spark plug connector(#1 being on the very top carb, #3 being the very bottom). Engine starts to stall and plug head clicks madly. So far so good. I pulled #2. Nothing happens. Engine keeps running. Here is the weird part. #2 only clicks when I hold it right up next to the plug head. Also the clicking seems weak compared with #1. Now I do know there is power flowing through #2. How you might ask. Well, I accidentally grabbed the pliers above the insulated part and shocked myself....so there is def power on #2. I pulled #3 and got the same result as #1.
From what I can tell this tells me that #2 carb is not firing. Why?
Could it be the ignition coil????
Well I switched #1 and #2 ignition coils and here is what happened....
I pulled the plug head on #1 carb (now with #2 coil) no clicking (same as I described above for #2) but engine still started to die. Pulled the plug head on #2 carb (w/ #1 coil) furious clicking but engine did not stall at all.
Seems to me (old) #2 coil is somewhat "bad" which could be related to the occasional stalling I have been seeing after running for a long time at idle. I think I am going to replace it anyway but it seems that the coil is not ultimately the problem I am facing now.
So....Now I am stumped. What can I test from here before I start having to throw parts at it till it works?
Also, I cleaned all the connections from power pack to spark plugs etc
Also I thought about the stator being bad? But honestly I have no idea if this is possible with the symptoms I have described...I did look at the stator and noticed a little bit of the "candle wax" dripping that can indicate a bad stator but I have no idea if it is actually bad or not.
I can post pics if that would be helpful to anyone.
Thanks in advance for all the help guys...This forum has already helped me through a few different issues and speaking for the people who don't really know what we are doing; we really appreciate all the help that those of you who do know what your doing give to us.
