snookhooked
Thread starter- Joined
- Aug 19, 2008
- 159
I have a 150 1992 evinrude that when you are starting the motor, the choke squirts out fuel. it looks like a valve stem that has a red lever. it loosen or tightens but my question is if there's a rubber seal that may be going bad and is it something I can replace? it only leaks when starting the motor but stops when you stop cranking the motor. it doesn't leak while its running. I just feel that its should be a simple fix.
